Lemme know what you think...
He wont need them. The port walls themselves will act as proper bracing. All I would worry about would be some triangle braces in the corners and thats it.
This will be my first box.. so i'm not sure what traingle support is can you explain to me or maybe a picture of one... Thanks!
all i can say is Build it,test it, and probably build another one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thats how it always goes
it's a 90 degree triangle, place it in the corner of the box and screw it in from the outside. All this does is adds support to the sides bottems and tops from flexing and pulling apart.
From about 5 boxes ago. Look in the top right corner, that's a triangle brace. It wasn't necessary on this enclosure, so I just used apiece of scrap and didn't make it the height of the box. You should always want to make it as tall as the inside though, that way you can couple the corner to the top and bottom.
raven15
raven15
michigan
coolahan
