Led Wires? Which one is positive
Leds work on both neg /postive you will see one way be brighter...Trust me look at my avatar if you disagree
Wait..Isnt an LED a light emitting DIODE? Doesnt a Diode prevent or condition electricity from "switching" Directions? Only way I could see that working is a higher Voltage then the recomended. I may be wrong though.
you can order them with the anode longer or shorter I thought. depending on how you want the LED to work. get 2 AAs and hook them up in series. touch the leads. one way will work, one way won't.
if the led lights up backwards, I believe you are overloading it by quite a bit. LEDs usually don't work at 12v either, more like 3.3 or something.
Black Truck 10
Black Truck 10
Houston, Tx
djman37
