Last thread haha...Does anyone know if you can wire 4 mids and 8 tweeters all 4 ohm
well, that amp is a 4 channel. you got two pairs of comps and four extra tweets. put one comp set on the front channel and the second on the rear channel and the extra tweets put on the deck fron and rear left and rights.
Yeah the way that he has suggested.
if you wire the tweets in series, then the 8ohm load will actually play lower, and be pretty harsh, likely with distortion. if you parallel them, they will go the other way, and it might work okay if the mids can handle that high of extension without too much drop-off, but i doubt it, especially if the mids are filtered to cut highs at the point it blends with the matched tweeters. as mentioned, run the 4 tweets from the head unit power, and the component sets from the amp. i, personally, have never had/seen an impedance issue running the tweets at 2ohms, and mids at 4ohms, as far as 4ohm stable amp is concerned. my question is: do you really need to have 8 tweeters in the frist place?
if you google diy cross-over building, you can get the proper size capacitor to put inline with your tweets to get the right high-pass frequency, and save on buying cross-overs.
---------- Post added at 02:37 AM ---------- Previous post was at 02:37 AM ----------
Why do you need 8 tweets
lol, nomsayin?
DropDownLowYota
DropDownLowYota
Honolulu, Hawaii, United States
akheathen
