Jordantyler
Lanzar VIBE228
600 Watt 2 Channel High Power MOSFET Amplifier
Rate and read reviews.
Technical Specification
RMS Power Range : 300-400 Watts
RMS: Root Mean Square is a formula that provides a reasonably accurate means of measuring and comparing continuous AC power. The use of this measure is preferred when matching system components, like amplifiers and receivers.
Number Of Channels: 2
Number Of Channels: Common name for a complete amplifying stage in any audio amplifier. Most amplifiers are denominated as 1, 2, 4, 5, or 6 channel units. Each of these is a discrete audio amp on its own, capable of taking a small line signal input and amplifying it sufficiently to be heard on an appropriate speaker. Some amplifiers are capable of bridging two channels together, to form one channel of double the power of each separately. The manufacturer's instructions differ widely on how to accomplish this, and each must be followed exactly.
Maximum Power: 600 Watts
Maximum Power: The amount of power a speaker is estimated to handle during a brief high-intensity musical burst. Since this can vary with both frequency and amplitude, it is a much less accurate way to judge speaker durability and performance than RMS.
Low Frequency response: 15 Hz
Frequency Response: The range of frequencies that a speaker will reproduce (lowest frequency to the highest). While the optimal normal is 20 - 20,000 Hz (Hertz), the range of human hearing for individuals is often much more restricted. A good full-range speaker system however, will reproduce as much of this range as possible in order to cover all variations. Individual Drivers are limited to reproducing only that part of the spectrum for which they were made, so their response will be limited, but still a necessary point to consider when designing a complete sound system.
High Frequency Response: 35000 Hz
Built In Crossovers: Yes
Crossover: A device or passive circuit used in systems with separate tweeter and/or midrange Drivers. It Rolls Off frequencies above and below certain points in the range, to allow the sound to be tailored for the specific driver to which it is sent. Most speakers have crossovers that consist of passive elements such as capacitors, coils, and resistors to separate the various frequencies. In a bi-amped or multi-amped system, the crossover is an active device that feeds the various frequency bands to the inputs of the amplifiers that operate the individual drivers.
Features
2 x 150 Watts RMS at 4 Ohms
2 x 300 Watts Max at 4 Ohms
1 x 600 Watts Max at 4 Ohms Bridged
2 x 200 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H x 10"L
is this a good amp??
Features
Bass Boost Circuit
Tri-Mode Capable
Gold RCA Inputs
Soft Turn On/Off
S/N ratio: 90dB
