Sold lanzar opti2000d $200.00 Plus Shipping
Jason19
I got a nice working lanzar opti2000d asking 200.00 plus shipping amp does 2000 rms at .5 ohm stable
Mono Block Subwoofer Amplifier
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Remote Bass Control
Soft Turn On/Off
700 Watts RMS Power into 4 Ohms
1100 Watts RMS Power into 2 Ohms
1600 Watts RMS Power into 1.3 Ohms
2000 Watts Max Power into .5 Ohms
2600 Watts Bridge Max Power Into 2 Ohms
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
Worked really well used it on my 2 12 inch type r 12's at 1 ohm and it cracked my windshield so im selling everything.
Jason19
Jason19
Kenosha Wisconson
Jason19
AJ (ACE)
    Jun 28, 2026
