Lanzar OPTI1232D vs Power Acoustik MOFO
subbin
Im thinking of getting one of these 2. Which one should i get? If there are better subs than these at a better price please share. My budget 150$/ ea for a sub its going into a new 2009 c300 benz, would like a mix of sq and spl
Lanzar OPTI1232D$149.00 http://www.onlinecarstereo.com
* Sensitivity: 88 dB
* RMS Power Range : 1100 Watts
* Peak Power Handling: 2200 Watts
* Impedance: Dual 2 Ohm
* Low Frequency response: 26 Hz
* High Frequency Response: 800 Hz
* Diameter: 12 Inch
* Custom Tooled Die-Cast Aluminum Basket
* Aluminum Alloy Cone Structure
* Massive Butyl Rubber Surround
* 3" High Temperature Dual Voice Coil
* 65 Oz x 3 High Density Barium Ferrite Magnet
* Power Handling: 1100 Watts RMS/2200 Watts Peak
* Frequency Response: 26- 800 Hz
* Impedance: 2 Ohms DVC
* Efficiency: 88dB
* Includes Installation Hardware and Template
Power Acoustik MOFO $129.95 http://www.caraudiodeals.com
* Brand New Power Acoustik MOFO12 2400W 12" Subwoofer
* 2400W Max Power
* 1200W RMS Power
* 270 Oz. Magnet
* 3” BASV/Kapton Hybrid 18 AWG Voice Coil
* Non-pressed paper cone with aluminum rib insert (patent pending)
* Dual 2 Ohm voice coil
* Die cast aluminum
* Metal-flake Royal Blue Finish With Diamond Cut
* Chrome Finish Front & Back Plate
* Large foam rubber surround
* 1-Piece Rubber Gasket
* Dual Conex Spider
* Woven Tinsel Lead Through Spider
* Chrome Screw Terminals
* Mounting Depth: 6-1/2"
* Deluxe Wood Case Package
Something better as?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what's your budget?
I recently saw a couple eD NINe.1's for sale for around $200, that would be a much nicer amp that either of the two you listed. What subs are you going to be running, your final impedance load will also help determine what amp to use.
what's your budget?
My budget around 150 a sub
I meant how much are you looking to spend on an amp...
Your best bet is to save up a little more money, it would be worth the wait... you don't want to have a benz, and put some crap *** audio system in it.
LOL, very good point , i really don't have a budget i just dont want to waste to much money because i also want to get rims. I'm thinking $1100 or inder in total (amp ,sub, sub/amp wiring, box, capacitor and anything else i need), i have no idea what amp i should get like said before im clue less when it comes to subs/amps lol. How are the FI BL 12" do they pound?
My buddy has one Opti1232 on a quantum audio 1500 watt amp and it gets pretty loud. SQ isn't that great but if you're just trying to get loud it's not bad for the price.
subbin
subbin
yo mommas, bed
GlocksRock
