Lanzar opti 6000d
cal
LANZAR OPTI 6000D
1 x 3000 Watts RMS @ 4 OHMS
1 x 4000 Watts RMS @ 2 OHMS
1 x 6000 Watts RMS @ 1 OHM
Mono Block subwoofer BIG POWER amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB
Gold plated RCA Inputs
Gold plated Line outs
Custom Terminal Block for speaker Connections
Thermal,Overload Short Protection
Variable Low pass Filter (50Hz~150Hz,24dB/Octave)
Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Remote Bass Control
Input Impedance:10K Ohms
Soft Turn On/Off
THD: 0.1%.
S/N Ratio: 90B
Input Sensitivity: 200mv~4V
Freq. Response: 20Hz~250Hz
Dimensions :10.08'' (W) x 2.12'' (H) x 27.6'' (L)
amp is used has its share of scrtaches take a look at pics.
amp has never been blown when i got it the led light did not work and the crossover had 2 caps that needed replaced because it was not filtering properly besides that no other repair has been done.
amp is fully working no issues no stripped screws the only thing is the remote screw when most of the way up is a little loose but once tightened no problem this may be normal but i noticed it and thought it was weird .
amp comes with remote gain and cable no original box .
675 SHIPPED WITH THE TRIPPLE IMPUTS.
FREE CONTINENTAL U.S. SHIPPING .
PAYPAL ONLY AND NO TRADES
http://www.caraudio.com/forums/itrader.php?u=1006316
tempted in getting it, so i can have two of them.//content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
i think you should get it . 2 of these guys would be insane
pending sale will update thread on sunday
sale was to go thru today no cash and no reply
so back up for sale
cal
cal
cal
