laid her down a 1'' 1/2
SethPhillips
I'sa Playa
had to do it... was gunna wait till it was spring... but i was at the shop and i figured **** it..
before
after
i got board and fiberglassed my Rockford Fosgat volt, temp display into where my clock was.. still need to wrap it in black vinal..
rides pretty good.. i think that volt temp meter is awsome after playin with it for tha last few day's..
**** i was gunna do that i got pretty much the same dash. Was it hard? what did u use for a base to build on?
made the bas out of 1/8 mdf. the same size of the clock's outter becel.. then a smaller frame to hold the display.. then i used toothpicks to get the right angle.. then tapped off the inside where the display was gunna go.. and just used boddy filler. got it to the right shape.. sanded. and threw a quick paint on it... when i vinal it it will pressure fit right in there with no glue or tape..
Looks great was thinking on ways to do it thanks
tenin coilover's with eibach springs.. front upper aluminum control arm's so i can adjust my toe in toe out..
nice, can't beat that setup.
now you just need do somethin with the orange parkin lights and red tails. you could get some spray tint for them and i think it would really make the exterior flow alot better. nice ride regardless.
nice, can't beat that setup.now you just need do somethin with the orange parkin lights and red tails. you could get some spray tint for them and i think it would really make the exterior flow alot better. nice ride regardless.
im gunna buy these nica smoked turn signals for the front.. they will look tit's.. no clear bullshit on this babby.. gunna tint tha back tail's allso... maybe even the headlights.. but im not sure about that....
sittin behind tint.. gettin bent.. you cant see me but you smell the smoke..
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
BP1Fanatic
BP1Fanatic
