L7 or 13w3v3
FACTS:
You are still an idiot
You are a JL Fanboy
The Kicker will take lots more than W3
I don't care about piston area
The only thing i pull out of my *** is your mom's face after i'm done cleaning my anus folds
There you have it.... (his imaginary facts)
meanwhile back in reality,
His definition of idiot is someone who thinks his opinion is wrong
I regret buying JL, and wish i'd bought RE subs and sundown amps
so i'm a fanboy:wow:
The 13 JL will keep up fine in power handling with the 12 L7
piston area is going to be the biggest equalization factor between the 2 (to say you don't care about it makes you an idiot. in most cases its the only real edge in SPL kicker has)
coming from the guy with the 145hp $8000 Italian chip and mixmatched subs.....i never said i don't like JL, i think the W6 is one of greatest subs made, i said the Kicker will crush it
The 12" L7 is going to be very close to the 13w3v3 in output and the JL will have a slight edge in SQ (depending on install).
they have close to the same power handling and almost the same piston area because the 12 gains area being square.
The JL will actually run much cheaper though.
Ugh.. You again
When are you gunna learn that the truth of the facts have nothing to do with where they came from?
ok all mighty wise bonesninja....
Why will the S12L7 crush the 13W3v3 in output?
bet his answer is somehow sarcastic, and i'll tell you why...
you can spew all the technical mumbo-jumbo (that you read somewhere) that you want.....i have real world experience with both and its not even close. So now tell us what you think you know, and then go away.....no one wants you here and you don't contribute shit so just go away back to your single wide and leave us alone
the 13w3 wont take much more power than the 600 its rated at and the l7 has proven its capable of handling well over 1000 watts and twice the excursion./thread
the w3 can handle way more than 600 watts and at 1000 watts the L7 starts to sound more like a wet fart.
I would chose an L7 any day over any JL sub, simply because of my experience with L7s and the power i know they can hold.
id take a 12w7 over a l7, but thats just me, the w7 is a fairly loud andaccurate driver, and ive had both as well, comparing a 13w3 to a l7 is just retarded
are you speaking from experience or jsut assuming, i fed it 1200 watts and it sounded good, not the most accurate sub but far froma wet fart:rolleyes:
exactly....i know people feeding them 1500 daily and they take it like a champ....feed a W3 1000 real watts and see what happens
id tale a 12w7 over a l7, but thats just me, the w7 is a fairly loud and accurate driver, and ive had both as well, comparing a 13w3 to a l7 is just retarded
Its all opinion on what you want, and i have had L7s and not JLs, so its just me, and yeah personally i believe why compare subs, just try them out and see which one you like better.
Hey i was right! hahaha sorry (entertaining myself)
i've also got experience with both of them, and yes a system with ported 2 S12L7's and a system with 2 ported 13w3v3s sound very similar
Dougsub
Dougsub
Saint Augustine, FL
cotjones
