lol, when i did my box with the kerf i used a circular saw. first i took a straight edge of a board then clamped it into position, then took the saw and sit it next to the clamped board as a guide, made a cut, then took it off and measured how far from the clamped board the cut was. that gave me a general measurement to know where to clamp and where my cut was going to be. worked out pretty good for me and gave me the straight cuts i needed.
IMO, make lots of cuts. don't just go for bare minimum. the closer the cuts the more flexibility you have along with a smoother curve on the frontside. if you make few cuts, when you bend the wood you will most likely end up with a lot of straight bends and to me isn't as appealing. you can sand it down to be smoother at the bends but it will then begin to loose it's strenght as your taking away the little amount of wood it has left..
i don't know if mentioned or not but i would also recommend you to fiberglass the cut side to give additional strenght and so the kerfed area can settle and not want to bend back.
