Kole QX1-3000d=PA A3000db?
They are the exact same boards. Are you wiring your sub/s at .7 or do you have a box rise of .7? If this amp see's a box rise below 1 ohm it will go to protect. It will give you about 1500 real watts rms. Good luck.
I've got a LNIB Power Acoustik Gothic series 4000. it's rated at 2200 rms at 1 ohm
200 shipped
I just bought it a few weeks ago so I could do some testing on my system, but I don't need it anymore
^^^^ Did you do a power test using DMM's to confirm that? A BAMF-5500 doesn't put out 2200 watts rms on a 12 volt system, so how are you getting 2200rms out of a BAMF-4000D? Also you may be able to wire the amp down to 1/2 ohm and it won't clip, but that is because your box-rise isn't falling below 1ohm while playing music. Try doing a power test on the amp at your burp frequency and post your results.
who the hell is talking about a bamf???
I have one of the Power Acoustik OV1-5500D, same board as the 3000. I have been running it @ .34 for a couple months now. Imp rise, probably 1 ohm and some change. Amp will do probably 2200-2500 on 14.4
What tells you those are the same board? For one, the ov1-5500d is fused, the a3000db/qx1-3000d is not.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
n2audio
