kole audio????
Here is some info I received from PA (Power Acoustik, who makes Kole) on the Kole HK980-2 and Kole amps in general:
The amp lines HK and Q are the same, just the name and heat sinks are different. Kole amps are very similiar to the Power Acoustik amps. The HK980-2 has two 35amp fuses in parallel and has a dampaning factor of 200. So the amp should be able to do it's stated RMS power if I understand how the fuses are working (35amp per channel).
I've also read (from others who sell them) that the Kole Digital amps are the same under the hood as the Planet Audio Digital Amps or at least the Kole 3000D is the same as the Planet Audio 2500D.
A friend of mine is a distributor to them. He says:
"They are too new to really have any long-term feedback but everyone else who has them is receiving good feedback on them. PA makes solid stuff, especially for the price. I have never been disappointed at PA's performance and Kole is the upline to both PA and SPL."
I hope that helps. I can't comment because I haven't heard one but it sounds like they should be fine.
thanks for the specs.do you feel that i would be better suited to get the tsunami bd1100..or the kole thats putting out 2300rms..
Both amps are pretty new to me compared to most other brands. Ask Tsunami and Kole. Call them up, tell them your situation and what amps you are considering, what you are expecting, etc.
They should be able to help you more with this question than I can for sure. They are the ones that are selling and building the amps.
Kole:
karl@poweracoustik.com
323-722-3333
They are pretty new. My friend is installing his 4-channel amp from them this weekend and I'll post his review if you want when he does. They are the upline to Power Acoustik, so found out what people think about them.
Tsunami:
I can't seem to find their website
415-776-9705
If you are going to get the Tsunami, call them. They aren't on the ED website anymore. I don't know what that means. The bd1100 seems to drain a lot out of car from some of the reviews I've read about them.
Have you considered the Hifonics Brutus BX1500D or other amps?
snow96
PIMP
snow96
Texas
snow96
vegang
vegang
