Koda Tweets
avistar23
www.SoundhertZ.com <---
Whats the best replacement for a koda tweet, also does anyone know the impedance of the stock ones. One of mine had a problem i fixed it (tinsel snapped inside the dome, i took the dome off and fixed it but im not sure how long it will last, so whats some good replacements, Can i buy some from adire?
-Mike
hmm I wonder if that is what is wrong with my tweeter from my old comp set, the tweeter does not make any sound at all, hooked it to a battery and nothign at all.
Did you just re-solder it?
well i had to take the dome of the magent, then put another wire from the break to the terminal, then make it all lign up and put it back on, and u have to be carefull not to melt the tinsel, it was exactly easy.
-Mike
The Koda tweeters were a slightly modified Peerless RDC2000
Adire had the OEM Peerless RDC2000 modified slightly to allow better off axis response, and a slightly smoother top end.
As always //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
avistar23
avistar23
Nassau Bahamas
strong*I*bumpin
