Knukonceptz or Kicker?
Knu all the way I run it. I works great.
So thick.
Kicker is a little skinnier and not as flexable.
Also knu wire is also more high current and can get disperse hear better.
kicker 1/0 is pretty **** thick and hyperflex is pretty **** flexible:fyi:
So thick.
The choice is so obvious, even the illiterate know the answer.
I can wrap knu around my pinky, easily.
The KMLX isn't nearly as flexible, but its good for cheap runs.
I like to run kmlx, and then change over to the fleks wire when needed (by the engine compartment, the change is done via fuse block)
I would actually go with kicker on this one. Seems like it gives you more stuff
http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK20
What you get:
- 18 Feet 0 Gauge Blue Kolossus Fleks Power Wire
- 2 Feet 0 Gauge Smoke Kolossus Fleks Ground Wire
- One FH-20 with Choice of Fuse size
- 2 Black / 1 Red 0 Gauge ring terminals
- One KNF-12 Two way Fuse Block with choice of two fuses
- 6 Feet of 4 Gauge Blue Power Wire
- 8 Feet of 4 Gauge Smoke Ground Wire
- 2 Black 4 Gauge ring terminals
- 5 feet Split Loom and wire ties
http://cgi.ebay.com/Kicker-PKD1-0-1-Gauge-Car-Amplifier-Install-Wiring-Kit_W0QQitemZ290356174049QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item439a939ce1
What you get:
- 20 Ft. 1/0 AWG Power Wire
- 3 Ft. 1/0 AWG Ground Wire
- 20 Ft. 16 AWG Remote Lead
- Fuse Holder
- 300A ANL Fuse
- 2 Distribution Blocks
- 5 Ft. 4 AWG Power Wire
- 5 Ft. 4 AWG Ground Wire
So kicker gets 3 more feet of 0 gauge. An extra dist block, but isn't fused. 3 feet less of 4 gauge. No split loom but seems like its tekflexed(sp?). Kicker is also 10 dollars more, but gets free shipping. So it really is a toss up, comes down to personal preference.
go with the knu wire, as if you do have any questions at all u just email them and they will answer them usually that day or next business day. i have bought from them many times with not a single problem ever
galacticmonkey
Wants a button like that.
galacticmonkey
Tampa, FL
1hawaii50
