Knukonceptz Distro
Alright guy's i think i figured it out now. i found out how the compressions fittings work so it fits 4awg 2runs like said:D:). so i will just use the 1/0awg in and not the 4awg in correct?
That i do not know SPL140.2 . If you could tell me i would really appericate it ThX man cause i have the knukonceptz battery terminals ones that can accept any awg wires.
trim the jacket off the wire push it threw the compression fitting and pull back some strands all around the compression fitting, put it in and screw it tight. Thats it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
egg
alright man ThX that's easy enough:D:). thanks for all the help SPL140.2:). one more question for the ground on this distro so reads the voltage out does it matter how long u make the ground wire to the distro 2 read out the voltage or no not at all?
k nismos14 i didn't think so man . just thought id check //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. thanks for all the help guys.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
not yet man i have a while to go until i can install anything:(. here is a list of what i need to save up for/trade
Front stage amp
1/0awg kolouss or KLM wire
Sound deadner
Build the box
Tint all rear windows completely black
install comp set
batteries
I still have a while to go //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. but in end willl be worth it and im getn there slowly but i am:).
Did you get that direct from us? if so the directions are right on the back of the package...
http://www.knukonceptz.com/assets/Tech/knfhowto.pdf
The side with the larger fittings would be the input. We have two ports on the input. Only one is needed. The second can be used to connect a second battery, connect additional blocks or used for a second input connection from the main source.
The output side has the stand alone connectors. With the digital block you will need to ground a lead to the mounting hole to provide the negative 12V to power the LED display.
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
