Knuconceptz terminal problems.
The spade terminals that came with my Knukonceptz kit wont fit inside of my amp sockets. I'm talking the connection from power to amp, REM to amp, ground to amp, and the terminals that were intended for the speaker hookups. None at all will fit. What do I do?
go buy the correct ones
Oh dang. My camera battery is dead, so I'll try to provide more of an accurate description of the problem. The diameter of the hole where you put the terminals is too small for the terminal to go into. It could fit if I jammed it in there, but I don't want to fvck up my sh1t before I even get to use it.
dont use any. just strip some wire and shove it into the amp? if its the type im thinking of
That's what I was going to do at first, but is that a secure connection?
EDIT: That was another question I was gonna ask. Where can I get smaller 4ga. terms? I am totally alright with just shoving some speaker wire up in there.
this is your problem, you have spade terminals that are 3/8" and you need 1/4" spade terminals.
Synyster97XLT
Reppin' the 304
Synyster97XLT
Charleston, West Virginia
I Like Waffle
BP1Fanatic
BP1Fanatic
