Knowledge Test lets go bitchz
Sub Bass Woofrz
One ***** of a problem. I got the right answer can anyone else haha.
Hydrogen gas is produced when zinc reacts with sulfuric acid.
Zn(s) + H2SO4(aq) → ZnSO4(aq) + H2(g)
If 138 mL of wet H2 is collected over water at 24°C and a barometric pressure of 730. torr, how many grams of Zn have been consumed? (The vapor pressure of water is 22.38 torr at 24°C.)
[quote name='Sub Bass Woofrz']One ***** of a problem. I got the right answer can anyone else haha.
If 138 mL of wet H2 is collected over water at 24°C and a barometric pressure of 730. torr, how many grams of Zn have been consumed? (The vapor pressure of water is 22.38 torr at 24°C.)[/QUOTE]
@West ; likely haz this
we can compare answers //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif i submitted my answer thru webassign so i know its right
well the answer is .345 grams if you were wondering. Hope you sleep better //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I think you use pv=nrt to get the # of moles of H2
(you dont need to know the vapor pressure at all I believe)
Then you use know the number of moles of zinc (1:1)
then convert the moles of zinc to grams of zinc
I think you use pv=nrt to get the # of moles of H2(you dont need to know the vapor pressure at all I believe)
yea pretty much, also have to subtract the pressure from the water from barometric pressure though, then just PV nRT
oh and its also a 1:2 mole ratio because H_2.
---------- Post added at 11:12 PM ---------- Previous post was at 11:11 PM ----------
= 1/12 sin^4(3x) + C
nicee... on that bish i forgot to chain rule the sin^3(3x) so i got 1/4sin^4(3x) ... better than me :p
Sub Bass Woofrz
Sub Bass Woofrz
Camas, WA
skylineTT
vegang
vegang
