KLMX for big 3?
if that is the cheap 1/0 from knu please dont get it. ive used it on several installs and that wire is just meh. its oversize so it doesnt fit any terminal rings. just fkn sucks to work with. just get the flex or whatever its called
Well i used the 4guage for my power wire/gnd to my trunk, and i thought it was fine.. the only thing im concerned about is it saying "made for lighter current loads"
1/0 will give you problems. dont use knu fuseholder if you do get that wire. it will do fine for the big 3 since you are using such shorter pieces. its copper clad which is why it cant handle too big of a load like 100%ofc wire. either way if you are fine with using it then go ahead and get it. i will never recommend it to anyone again.
i think it depends on your system.
if you think that your system pulls out more current than the KLM could handle, then don't use it.
for smaller systems, you will be fine. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm using the Knu Kolossus Fleks Kable 1/0 for my Big 3 install...looks mighty capable of handling the load! //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
06goat
bumpin bluegrass
06goat
Michigan
06goat
