kinetik vs optima under the hood/in the back
Redtop under the hood and the Kinetik in the back.
I believe the Kinetik's have a higher discharge rate, thus will act as a better battery bank than a redtop could.
I could be wrong, I've never researched it so I'm just going by my assumptions off of other people's posts.
so just + to + from teh red top to the kinetik
and same for the ground? - to - from the red top to the kinetik?
any fusing?
other then the one close to the redtop going to the kinetik?
after that i just wire my amps up straight from my kinetik to the amps? no fuse?
+ and -???
so no body ground? just straight from the - post to the - amp plug?
if you put the kinetik in the back you can just hit the frame/chassis for ground, no need to run it all the way up to the front batt neg unless you want to.. It wont hurt anything
oh okay
yeah thats what i was thinking.,
unless id have to run another run of neg which would ****.
hmm okay
fuses though.. thats my next question?
only one by the battery?
none after that>
not even to the amps?
Redtop under the hood and the Kinetik in the back.I believe the Kinetik's have a higher discharge rate, thus will act as a better battery bank than a redtop could.
You have it backwards. The redtop is a quicker discharge/starting battery while the Kinetik is a slower discharging battery that has more reserve. However, I do agree with the way you said to place the batteries, that's how I would.
awpsome
awpsome
Honolulu, HI
awpsome
