Kinetic HC2000 alone or together with stock Battery
eroc162
Hey guys Im new the battery stuff. I have a 12w7 and a PDX1000 amp with a 2 farad cap (stock 90amp altenator) and my lights dim a bit so I ordered a Kinetic HC2000 Battery which hasnt arrived yet. Is that a good enough battery to run alone or do I keep both batteries. I figured a deep cycle battery would be best.
Ah, the new guy eh? Ditch the cap, worthless piece of junk. Its not a battery, and doesnt help with dimming or what ever someone told you. But I would just add it to the stock, doesnt make since to ditch the front one. Thats more juice for the amp.
My main battery is in the trunk of my car. So I guess both would be in the rear. That sucks. lol. Anyone have any pics or suggestions on how to hide the extra battery.
I have a Bmw so both batteries will be in the trunk. the stock battery is in the right corner of the trunk under a panel. My amp is right over the stock battery in a cabinet I made. the kinetic battery was going to take the stock batteries place unless you guys think otherwise . Its only a 1000watt system and my lights do dim a bit now.
I just installed the kinetic hc2000. The dimming is much better but I still get a slight dim. I only have 1000watts. If I open the doors while the music is on the lights dim more noticably. Its grounded directly to the frame. I have 4guage cables everywhere and the voltage is at 13.80 idling. I give up. any help. I do have the factory headunit if that helps.
just keep both batteries and upgrade to 1/0 gauge wires..dont need that much since your batteries are in the trunk..that must be sweet to install a system in and you dont need to run them thick *** wires all over your car...lol
eroc162
eroc162
New Jersey
BloodyGuts335i
