kinda odd i think..memphis subs
thephoenixvampi
i just got 2 memphis m class 12" subs, and they are no where near how loud my 2 ensignia 300 rms subs were w/ the same amp. - crunch 1100.2 pe wired at 2 ohm stereo. getting about 200 rms i believe. in a 1.25ft cu. dual q-logic box
any ideas?
if it's the amp, can i get some sugestions for a budget hi powered amp that i can use to upgrade later with?
only issue w/ that is both subs are wired in parallel separately on it's oown channel on the amp, and both sound the same, with just one or both subs hooked up
yes if you getting same sound from one sub as you are with two then there is a problem.
Verify the final impedance your amp is seeing with your DMM.
how exactly do i do that?... they should be at 2 ohm per sub.....but, then again i am rather new to this.
i have a dmm and i used it to set the gains - the rest of the car sounds great btw....
Build a new box //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
to check just set the dmm to check resistance and red and black at the terminals
thephoenixvampi
thephoenixvampi
h.b., CA
thephoenixvampi
