james33440
Check this link out http://www.kicker.com/ShowPage.cfm?filename=sxstereo.html&menu=SXAMPS
Here are some specs of these amps. Look at all of these features. Can U believe it, an onboard DSP with a menu feature display? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Fully adjustable digital low-pass crossover with variable slope and crossover frequency.
•Fully adjustable digital high pass crossover with variable slope and crossover frequency.
•Fully adjustable KickEQ single-band digital parametric equalizer with variable Q (bandwidth), variable center frequency and variable boost or cut
•Adjustable channel output phase; left and right channels can be linked or independently adjusted.
•UltraMatch Gain Structure; left and right channels input gain control can be linked or adjusted independently.
•SickBay and On-Board Diagnostics tools to troubleshoot installation issues and check amp status.
•Kompressor - Four-setting, user-selectable bass compressor to fatten up your sub bass and adjust to compensate for speaker size, speaker location, vehicle size or listening style.
•Low Impedance Operation
•SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal) protects amplifier from accidents and out of spec operation.
•MOSFET Power Supply for high efficiency operation.
•PAST (Pre Amp Signal Transfer) RCA output jacks to pass the incoming signal to another amplifier or component.
•SAMS (Stereo And Mono Simultaneously) lets you into a bridged mono load and a stereo load at the same time. (Not available on mono amps)
•BLAST Port (Bass Level And Signal Transfer) gives you Remote Bass Level Control and control of signal transfer between multiple SX amplifiers.
•Amp Strapping lets you combine two mono amps into a single unit with double the power.
Can't wait to try these out. Not sure when they ship. When they do, I will let everyone know. Or, let me know if someone finds out before me.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
