Kickers and fosgate amp help!
why r u giving advice when u have no clue what ur talkin about?!
2 d4 woofers can be wired either to 1 ohm or 4.
Since I think that amp is only 2 ohm stable ur gonna have to wire it down to 4 ohm, it's the only option.
Thanks, although my only question is how would i wire that, could you send me a diagram or something. Also when i wire the two subs together both at 4 ohms how much watts would each sub be recieving
Never look at max specs, rms will give u true wattage.
So ur subs are 400wrms, which means that amp will be perfect.
For wire, use 4 gauge for power and ground. Use 14-16 gauge wire for speakers and remote wire.
Never look at max specs, rms will give u true wattage. So ur subs are 400wrms, which means that amp will be perfect.
OK thanks alot man, your input is def making a difference. what would you say is a better set up one 12" kicker L5 or the two 12" cvrs
Avalon03
Avalon03
San Antonio, TX
Avalon03
