kickerl7
siddyboo
I am looking to buy a loud system I was thinking of getting 2 2ohm 15l7's and 1 KX2500.1 would these work together ? I am not sure what to get 2ohm or 4ohm would this amp power the 2 ohm because it says 2500rms at 2ohms ????
someone help me please i want to order my stuff !
yes, that will work perfect...the KX25001 needs a 2 ohm load, so you'll need two DVC 2's to achieve that. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Ought to slam!
In series thats a 8 ohm load, and in parallel, thats a 2 ohm load... Where am I going wrong?
1/2 ohm...all three of these with 2 DVC 2's
2 ohm
8 ohm
Thanks and how would I go about plugging the amp into my stock head unit ???
also how do you power the amp ???? Also would I need to strenghten the electrical system my car has a 110 volt alternator and if so how ?
Thanks and how would I go about plugging the amp into my stock head unit ???also how do you power the amp ???? Also would I need to strenghten the electrical system my car has a 110 volt alternator and if so how ?
I would have a shop install the amp and set the gains, etc...be much easier, and safer in the long run, then they would be liable...
siddyboo
siddyboo
Canada
Polecat
