Kicker ZX750.1 question
brian1226
i have it hooked up to 2 12'' Kicker CVR's at 2 ohms.. it says each CVR is 400 watts rms so does the 750 watts rms from the amp get split in half to 375 watts rms to each? .. Also theres an input level button that says hi or low, whats the better setting for this setup and also do u recommend a good gain & bass boast setting for this setup thanks
if your running RCA's from your H/U = low
if your tapping your rear speakers for signal = high
bass boost should not exceed 6db gain, ever.
I usually like a 3-4db gain at 38-40 Hz.
buy a dmm and search on how to properly set your gains
i have my amp crossed over at 80 hz on that setup and i'm adjusting my gains for max performance.. would using an 80 hz tone and adjusting gain untill it distorts and backing it up from there be the best way to do it?.. also i have my amp & deck crossed over at 80hz, but i heard since the deck only feeds 80hz (or lower) to the amp anyway, i can just turn the amps crossover to max?
brian1226
brian1226
medford, ny
brian1226
