Kicker zx750.1 pulsating protection!! HHEELLLLPP
chasestrickland
WTF my zx 750.1 took a dump for no reason. When I hook it up and turn the car on it just goes in to like a pulsating protection mode. Im thinking that it has to be an internal problem because I can unhook that amp and hook up my Audiobahn 750 2 channel amp and it works perfect. Anyone have any ideas on what it might be???
what do you have the subs wired to and also how did you set your gain?
dual 2. Could it be too little of a load for the amp?
If you have it wired down to 1ohm, yes. Kicker amps are only stable above 2Ω. Running it at 1Ω will pulsate protect just as you are explaining it. Rewire it to 4Ω and I'm 95% sure this will fix the problem. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
Thanks for the help. I really appreciate it. I'll post if it works or not. I took the amp apart to clean it and inspect it so I gotta put it back together
No problem, good luck, let us know. I'm 95% sure this is the problem though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
If you're running it below two ohms, its going to do this everytime.
i ran my kicker zx1500.1 at 1 ohm for a couple months and it DID NOT go into protect once and didnt even get hot.
it is still running perfect a year later although im running it at 2 ohms now
chasestrickland
chasestrickland
Vero Beach, FL
chasestrickland
