Kicker ZX750.1 @1ohms?
Yes, I've never had an issue with them at 1 ohm. They give a bit warmer, but that's about it. Just make sure you keep your voltage at 12 or higher all the time.
...but don't blame me if you kill it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well i would def not blame you if i blew it lol. My voltage def drops below 12v because i go out to my truck and demo it at idle very often for my job. What kinda of power increase do you think i could estimate
I have the same ? about my zxs1500.1....it's not hooked up rite now. But can I ran it @ 1ohm wit out to much trouble? It's tha small or mini version I guess. Does tht make it any less capable? I wan'a use it until I can afford 2.5-3k amp
I'm not even going to guess. Not a ton.
I've only used the ZX line so I'm not sure. Try it but do so at your own risk. Most setups will rise above the rated 2 ohm impedance after box rise.
MerkConvoy501
MerkConvoy501
Conway AR
psych0ticnemes1
