AK SloPok
I have a Kicker ZX700.5 in my 2005 Chevy Silverado. The problem I am experiencing is it will turn off at moderate volume. At about 3/4 volume (gain setting at about 60%) when I get a heavy bass note, the amp shuts off after 3-5 seconds it restarts and plays fine, if I lower the volume to around half it will play continually. This only happens after the vehicle has been running for about 10 minutes and especially after sitting at a stop light or pulling away from a light. My voltage gauge reads a steady 13.5-14.5 at the dash.
This is the only amplifier I have in my truck. I was running two cheap Phoeinx Gold amps before with similar output without the wiring upgrades and never had an issue. I have 4 gauge wire run from the battery to the amplifier, the chassis ground is less that 18", I added a 4 gauge ground wire from the battery to the chassis, I upgraded the alternator wire to 4 gauge, the factory battery is 600cca, and the stock alternator is 145Amp. The amplifier is wired to a set of components on the front and rear channels at 4 ohms and to a pair of 10" pioneer subwoofers at 2ohms. I have checked all of the connections, including the RCAs (dedicated for each channel) and have not found a problem. I have not been able to see if the protect light is coming on or the red light is coming on as the amplifier is not viewable when driving. I checked the temperature after coming home last night (after several shutdowns) and found that the amplifier was at 89.1 degrees f. Is there something wrong with the amp, the installation, or my truck?
Please help. This is not a problem when driving around with the family but it certainly is annoying and a bit embarassing when I am with friends listening to hip hop/rap. This normally only happens on a bass note.
My thought is voltage but I thought amps could run down to 12v?
Thanks for any information.
Chad
Chad
