Kicker ZX1500/2 15" L7's
4Chris4
KiCk3r OwNs FoSgAtE
ok guys i just sold my sx1250 today....i am about to order my zx1500...and my other 15...the subs are 2 ohm's....that will give me a 2 ohm load to the amp right? since the amp gives full power at 2 ohms instead of one....that was my first question...my second question is...i have stock electrical system...no big 3...and an ok duralast battery i bought last year...i need to know what i need to push this setup....it dont have to be to the absolute max...but i dont want nothing messing up either..like my vehicle...so i want to be able to listen to it without out it killing my electrical system....could i just buy a good optima battery and put under the hood and then do the big 3 on my stock alt? or do i need a new alternator...thanks for your help
Wht do u drive??....but IMO u should b fine using ur normal batt as a starting battery....then use the Optima to jus the amp nd do the Big 3...
okay thanks a lot guys...i drive a 95 s10 blazer (4 door) if that helps any....so you can do the big 3 on a stock alternator? and how would i hook up an optima battery to the amp?
You can do the big 3 on any car.
Run the batteries in parallel (Power wire from front battery => + battery to amp). Ground that battery to the frame or run a ground wire from that bat to the front bat. Connect the - from the rear battery to the amp. If you need any help with anything send me a pm.
Since you will have two dual 2 ohm subs you can wire them at either 0.5 ohm or 2 ohm.
To run it at 2 ohm you will to connect a positive to negative on each sub then run a positive and negative out of each sub. I would highly suggest doing the big 3 in 0 guage. I noticed you had to constantly keep your RPMs up to keep everything going with your sx1250, so you might need more than just the big 3 but I would definately start with the big 3 and see what it does.
oh thanks for the help guys...aaron yea man thanks....im doing the big 3 and getting a optima yellow top batter in the back to push my zx1500....should pound pretty good man when i get it going...i just ordered my zx1500 for 441.00 brand new...pretty dang good price...im about to order my new cd player....a 07 kenwood
You'd hate to know what I got my zx2500.1 for:)
might look into geting a bigger alt...my kx1200.1 burned the hell out of my old alt...didn't realize it till we took it apart after removing it. The entire inside was burned from me trying to pull more power than it would give //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
you'd hate to know what i got my zx1500.1 at too,brand new with full kicker warranty.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
edit: to the original poster, i have a yellow top under the hood and a yellow top in the trunk, i've done the big 3, run 1/0 guauge kicker hyperflex, all on a 80 amp altenator with no problems.
what did you guys get your zx1500's for? thats the cheapest i could find one....i looked hard....i have the money though so i dont care...im sure its worth 440$....anyway you guys tell me about the amp....i had an sx1250...so i hope its better than that...
Same here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
4Chris4
KiCk3r OwNs FoSgAtE
4Chris4
Conway,Arkansas
Lakota
