kicker zx1500.1 question help please!!
dnb
I have two Kicker cvx 12" dual voice coil subs that rms at 750 would it be wise to connect the two of them at 4ohmd, that is if it can do it? I think it can do it i read on cardomains website it can but on kickers it didnt say anything. How would i wire them? Would I lose a significant amount of power doing it like this?
Here is the amp
http://www.cardomain.com/item/KIC06ZX15001
Here are the subs
http://www.cardomain.com/item/KIC06CVX124
On kickers website only said it was stable at 2ohm(mono) but on cardomain.com is says 4ohm but can i connect my subs since they at dvc's and the amp is mono?
you have two options, either running the amp at 1 ohm(you'll need a good electrical system,eg 2 batts or bigger alt but you'll get around 2000 watts to the pair) or you can run it at 4 ohms(only 750 watts to the pair)
dnb
dnb
Stuart, Fl
t-money
vegang
vegang
