W wnh4unc13 Junior Member 2 0 North Carolina Jan 12, 2008 #1 I have the amp, but should i get the 2ohm or 4ohm sub, and why? Thanks for the help. Click to read more...
outspoken 10+ year member CarAudio.com Elite 1,599 0 Between The Golden Gate And The Bay Bridge Jan 12, 2008 #2 if you mean 1000.1 then get the dual 4
Qbenjamin 10+ year member CarAudio.com Veteran 3,643 12 Braavos Jan 12, 2008 #3 the zx does 1000w @ 2 ohms. Get the Dual 4
thegreatestpenn 5,000+ posts lazy genius 9,487 40 columbus Jan 12, 2008 #4 amp does 1000wrms+ at 2ohm so you get dual 4ohm configuration and wire the sub to 2ohm
Lakota 5,000+ posts Doesn't Know $hit 6,277 1 Louisville, KY Jan 13, 2008 #5 I'd only get the dual 2 and run it at 1 ohm if you really knew what you were doing.
