Kicker truck box.
Are you looking for subs and boxes, just subs, loaded boxes?
I have two 10" round Q-Logic truck boxes sitting in my closet. I know, they're prefab, but they're yours for $40 + shipping. Mounting depth is I think around 6".
Custom build it, its easy. All you really need is a circular saw and a router with a flush cut rabbiting bit(If you know what i mean.) Drill counter sink and drill bit. Glue screws.
Buy the wood at lows or home depot. Have them do vertical cuts while the board is laying sideways on the machine(again don't know proper terminology).
Cut all 4 peices that way to make your front back top and bottom.(they will all be the same lenght 49")
Also might wanna get the port cut their to if your going ported.
Screw them together and glue, don't forget pre-drill and counter sink.
And for the ends just put a peice of mdf on the end and trace.
Cut outside the line. Screw it down and use the router to make it flush.
If your going ported make sure you make exact measurements. You can use liquid nails to fill up to 1/8 inch.
Gussets are also a good idea, if no cross braces are used.
Well, not to be snippy, but I know very well how to build a box. I built this one.
http://www.caraudio.com/forum/showthread.php?t=298673
I just want to see what is out there for sale.
I VERY much like your idea of the lenth of 49 inches.... thanks for that one.
I am sure you did but it is just, most boxes I see have the the side or end peices between the front baffle and back peice like this pic. And when making truck boxes those peices are the trickiest to get right.
And I find it much easyier and prettier to just slap a peice on the end and rout it to perfection. Makes the ends nice and flush. It also adds a little bit of air space.
I would build you one but it would weigh a ton.
Dude.
Seriously.
koolwhipman
Busy busy busy...
koolwhipman
A western Chi-burb.
koolwhipman
