Item(s) for Sale: I have kicker sx 1250.1 fs this is my favorite amp but have no use for it.I used it to power 1 si mag 15 for 5 years never a problem and in great shape 300.00
Item(s) Description/Condition: 312 watts RMS x 1 at 4 ohms (Kicker recommends a 2 - or 1-ohm load for maximum performance)
625 watts RMS x 1 at 2 ohms
1250 watts RMS x 1 at 1 ohm (1-ohm stable)
requires 2- or 1/0-gauge power and ground leads — wiring and hardware not included with amplifier
keypad menu control
variable low-pass crossover (30-200 Hz) with adjustable slope (choose from 6, 12, 18, 24, 30, 36, 42, and 48 dB/octave)
variable subsonic filter (10-60 Hz) with adjustable slope (choose from 6, 12, 18, and 24 dB/octave)
Digital KickEQ single band parametric equalizer with variable center frequency and variable Q
Kompressor expansion/compression circuitry with four settings: Off, Contour, Attack, and Redline
4 memory banks store intricate EQ cut/boost, low-pass crossover, phase, bass boost, sub-sonic filter, and compression settings
Sick Bay technology for real-time diagnostics and troubleshooting (includes pink noise generator)
preamp outputs
UltraMatch gain control for optimal input level matching
amp strapping circuit lets you connect a second SX1250.1 amp for double the power output
Price: 300.00 plus half on shipping
keypad menu control
preamp outputs
