Kicker Subs
What would you pick?
  • Total voters
    32
i would do the 3 L5 10s more cone area, larger than 8" sub will have better lows. but the ohm load will be 1.33 ohms. but i guess with imp rise and box rise it should be over 2 ohms...unless u just do 4 10s and have a even 2 ohms.
if u was to do 4 u will need the D4 and the 3 its the D2
the lowest load i wouldput on it is 2ohms
it probably is 1 ohm stable but i dont want to push it.
im sure this pushes out more around 1650. as i have not seen one = or underated kicker amp to date/
just trying to make all the options so that it would be using the full potential of the amp.
1 l5 can take 500w so 3x500=1500 +like another 160 or so from the amp.
My bad bro, just woke up and I can't read
lol no problem was just saying.
only problem is with 4 10"s i wouldnt have enough power.
with that i would only be powering each sub 3/4 of the rms.
When comparing 4 10L5's to 4 8L5's, that doesn't really matter. The simple fact that the quad of 10's will be more efficient means you will get more output with the same power... seems like a better option than running 3 10L5's at a higher impedance.
silvercookie
WRX
silvercookie
Queens, NY
kovemaster559
