Kicker Resolution 2-Way Passives. 18db slope @ 3.5 khz w/ variable tweeter atten.
BassAddictJ
FL
Kicker Resolution Passive Crossovers
I double checked with kicker and these passives were part of the RS-4, RS-5 or RS-6. They are 18db on the high pass and 12db for the low pass at 3.5 KHZ. They also have adjustable knobs for the tweeter attenuation. The cool thing with the knob is you're not stuck with a set level or switches for your tweeter. You can gradually adjust the knob until the tweeters blend perfectly.
One set is in great condition, the other set shows just a little wear. Although the internals look slightly different, both crossover sets have the exact same specs according to the techs at Kicker.
Asking 20 shipped per pair.
Fedex Ground or USPS Parcel post
Ref's: Years of selling here. You're in good hands
936
BassAddictJ
BassAddictJ
FL
erickson wong
Decebal
    Jun 10, 2024
