Kicker Questions
kickerman_1
OK question # 1...I have 2 COMP vr subwoofers 2 ohm dual voice coil 400 RMS in a dual 12" enclosure
would these be the proper type of amps to looks for
1) 2-channel 400 RMS @ 2 ohms
2) Monoblock 800 RMS @ 4 ohms
ALSO when these subs were 400 RMS each, but when loaded into a box the guy told me they are now 300RMS each for a total of 600 RMS...why is that:S
Because I have seen birthsheets on several we have sold lately....I would suggest a Kicker ZX750.1 amplifier. YOu can series your dual 2's up to 4 ohm each, then parallel the two down to reach a 2 ohm load which is the rated load for a Kicker ZX amp.
ps.....every birthsheet on these amps that I have seen has been 900+ watts. Two were 939 and 949 watts:naughty: //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
seems like a good thing there, i have mine off a 2channel mtx amp(until payment gets here) and it's fine. no real reason for not using either
kickerman_1
kickerman_1
Toronto
mtdewelf
