Kicker phone #?
67impala
alright i gotta send my kicker amp back or talk to them asap
and there online site is down... so WTF!
my amp keeps going into protection and its definalty ****ed...
cause i've checked everything i've wired my sub to 2 and 8 ohm's
tried putting the battery from my other car in the trunk right beside it cause im running 20 feet of power wire "big car..."
and there was about 3 feet between amp and extra batt...
i double checked the ground etc...
so amp must be ****ed...
So i gotta get kickers number and send it back to them
onlything is though i bought it at a pawnshop and its a 2003 kx 400.1 mint shape i got receipt to prove i bought it at the pawnshop will they still warranty it? its got serial # and everything too...
i was thinkin of buying it at the local shop here new and then takin it back but with them switched... but thats not right...
i got it cheap too so mabee pawnshop guy knew it was ****ed but said i could get my money back if it didnt work providing i get it professionally installed i had all the wires in my trunk from my other amp which pretty much melted on a hot day runnin it at 2 ohms... it was a old kenwood mono amp that pushed 130rms... soo whatever... and then this amp and it goes into protection... when you start to turn it up it will stay on at low volume and as soon as you start to turn it up click into protection.. i dont think my kenwood amp was 2 ohm stable on 30'c day cause when i cut out i put my hand on it and it would burn my hand if i kept it there any longer then i took it apart and the inside board melted...
so the sub should be fine right? its the amp correct?
alright i gotta send my kicker amp back or talk to them asap and there online site is down... so WTF!
The warranty will be no good if you bought it from a pawn shop.
Just tell them you bought it from a pawn shop, or a friend, or who ever you want. They will still fix it for something like fifty bucks plus parts, and parts are cheap 2.10 - 5.57 or something like that. That was on a KX800 that was purchased on E-bay. The first time it had the same problem as yours, cost 51.00 and 6 days. The second time, 3 weeks later, some dumb *** hooked speaker wires from relay that was intended for fan up to speaker outputs. It was sent back to them, after they were told that it was an unrelated problem, the cost that time: 6 days with no amp. In my opinion Kicker's customer service department are good people. Orion (Directed) on the other hand...Thats another thread. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
67impala
67impala
Edmonton alberta
goupinya
