kicker l7 keeps moving when no sound?
  • 3
Sharp_Shoota
UK
Ok i just put an l7 in my trunk and am powering it with a 700w QC amp, when i wire the sub normaly it works ok but then its only getting 350w right? so i bridged it to get the full 700w and it works ok but the sub keeps moving in and out even when there is no sound coming out and when i skip tracks n stuff, anyone know whats wrong?
i think it's dvc... not 2 sure if they make an svc l7... but if ur amp is a 2 channel amp and you are putting both + and both - on the terminals and bridging it then it's running @ 2 ohms bridged... and it's prolly not 2 ohm stable bridged
Ok here is some more info about my amp
QXT200 4 ohm 2 x 100W RMS (400W MAX) Bridged 1 x 350W RMS (700W MAX) 2 ohm 2 x 160W RMS (640W MAX) WRC included Variable 12dB crossovers | Variable 0-18dB bass boostInduction cooling fan | WRC ready2 ohm stable | RCA & speaker inputs.
I have this years model kicked l7 4ohm, duel voice coil.
It worked ok when it was bridged before but now ive built a new enclosure for it and when i put it in this started happening. Althp it cant be my box its exactly the same dimensions as my old one just better built and thicker. :S
What do you mean by out of phase?
Is it safe to still use my sub while its doing this? since it still plays fine.
Is your sub wired like this (both +s together and both -s together) ?
isnt that parallel jmac?
Yes ... Or he could wire it in series to 8 ohms for 200 watts ... I wouldn't recommend either, but I think he tried to wire his subs in parallel and accidentally messed up or something ...
thats why i was asking you cause i thought he jacked up the wiring.
yeh thats how i wired the sub coil 2 - is connected to coil 1 - which is connected to right - on the amp
coil 2 + is connected to coil1 + which is connected to left + on the amp
Thats how it said to wire it in the kicker manuel, how else should I wire it?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
919
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Sharp_Shoota
Sharp_Shoota
UK
Sharp_Shoota
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
