Kicker L7 15" vs Alpine SWR 12"
user error //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Did you use an o-scope and watch your signal //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I disagree
No. I meant reggie, you idiot.
It's like the cheapest of the cheap weed
well i mean it could be user error, although i dont see what i could have done, never used the O scope, and reggie? ive never heard that one but then again i buy from the dispensaries
Reggie is garbage.
It's what all the freshmen around here get, and pay way too much for it just to try and be cool
I've seen more problems with them than JL or kicker subs in my area... Assuming all of them are noobs using bass boost however the other two actually survived vs the countless number of dead type Rs on the craigslist adds.
710
ogitchadaw
ogitchadaw
Norfolk, VA
Jeffdachef
    May 20, 2024
    May 20, 2024
