Sold Kicker kx800.4, 1200.1, 700.5 and 12" L7's
blackmax
These are brand new in box. The amps are refurbs but as many know kicker uses all new boards.
kx800.4 this amp is extremely strong and can easily be used as a full range amp! $250 shipped
100 watts RMS x 4 at 4 ohms
200 watts RMS x 4 at 2 ohms
400 watts RMS x 2 in bridged mode
frequency response 20-20,000 Hz
selectable front and rear variable 50-200 Hz high/low-pass crossovers, 12 dB per octave
0-18 dB KickBass bass boost at 40 Hz
dash-mountable remote bass level control (for rear channels only)
KX1200.1 $225 shipped
# 300 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms, or 1200 watts RMS x 1 at 1 ohm)
# variable low-pass filter (50-200 Hz at 12 dB per octave)
KX700.5 This is a well built 5 channel! $250 shipped
70 watts RMS x 4 at 4 ohms (85 watts x 4 at 2 ohms)
210 watts RMS x 1 mono output at 4 ohms (420 watts RMS x 1 at 2 ohms)
variable high-/low-pass filters (50-250 Hz at 12 dB per octave)
variable bass boost (0-18 dB at 40 Hz)
channels 1-4 Class AB power, channel 5 Class D
Kicker L7, DVC 4ohm. These are 2002 model solobaric 12" L7's. They are Brand new! $375 shipped for the pair!
Rated at 750 rms/1500 peak
Bump for even lower prices. Prices are shipped to the 48 states.
KX800.4 $225
KX1200.1 $200
KX700.5 $225
12" L7's $350
This is the lowest these are going to be priced at.
I would keep this stuff but I am heading to the sql side.
I will consider trades for:
amp that does 500-1000 watts @ 4 ohms (for 4 jl 8w6's, dvc 6 ohm)
a pair of sql 12's
Audison amps
or whatever you think is along those lines
blackmax
blackmax
Boise Idaho
blackmax
