Sold ***Kicker KX350.4 ----$100 shipped***
Worlddre
Big Darkie
As the title states i have a Kicker KX350.4 for sale. Ive used it for about 2 months. But ive had it for a while longer. Amp works flawlessly heat sink has some scuffs on it but with some work they could probably be removed. Comes with both endcaps.
tis the amp on the right
i have plenty of refs on this here forum
Chefboyrlee
954runner
flakko
blados
GTO Zeta
Netherland24
Seth350
Mr. Loki
Red Rocket
Blazin Jason
kpozr2
Cyantist
any questions just ask and such
KICKER amplifiers have always ruled the winner's circle at car audio competitions because they combine remarkably advanced design features with the highest-grade electronic components and manufacturing tolerances for the ultimate combination of sound quality and brute power. The new KX series stereo amplifiers feature outrageous removable amp shrouds that scream “power.” Beneath the exciting exterior lies fan-cooled internals that have been designed from the ground up to deliver tight, clean power. An unregulated Class A/B power supply allows the amplifier to really pour on the power in 2-ohm operation. All this power is at your command with continuously variable crossovers, high- and low-level inputs, and variable bass boost. Fast-acting protection circuitry guards against short-circuits, over-voltage, overheating, or wiring mishaps. Gold-plated RCA input connectors insure maximum conductivity and resistance to corrosion. High 22kOhm input impedance lets you link multiple amplifiers in a single signal chain without having to use signal-robbing splitters. Custom-tooled remote and speaker screw terminals are also gold-plated, while oversized power and ground terminals allow positive connection. Dialing up just the right amount of bass is at your fingertips with the KickBass variable bass boost. KICKER even ships every amp with its own birth certificate – KICKER's guarantee to you that it meets their high standards for power and performance.
Features:
* Radically Advanced Chassis with Removable Chassis Shroud
* Fan Cooled
* Short Circuit, Over-Voltage, Reverse Polarity, Thermal (SORT) Protection
* MOSFET Power Supply
* KickBass 0-18 dB Variable Bass Boost at 40 Hz
* 12 dB / Octave High- or Low-Pass Crossover
* Variable Crossover Frequency from 50-200 Hz
* Delayed Turn-Off Logic Circuit
* Soft Start Turn-On Circuit for Reduced Startup Load
* Removable EndKaps Cover All Connections
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 60W x 4 @ 14.4V
* THD at 4-Ohm RMS Power:
* Bridged RMS Power @ 4 Ohms: 175W x 2 @ 14.4V
* Speaker Level Inputs: yes
* Preamp Outputs: no
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >95 dB
* Fuse Rating: 2 x 20 amps
great guy right here!
thanks man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
don't want to trade for a yellow top do ya? I could meet you at the cluck u again //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Worlddre
Big Darkie
Worlddre
Charlotte, NC
Blados
