kicker kx1200.1 vs rockford fosgate
both amps will put out about the same power but i think you can get the Kicker cheaper... i like the RF more though.
Either way you'll be fine
i doubt the rf is gona put out as much as the kicker
Believe me it will.
Most of the birthsheets i've seen of t10001bd are 1.4Krms or a lil more the same for the kicker 1200.1
but like i stated before... either way you should be fine
Believe me it will.
hmm somthin musta been not to good bout fosgates i saw, they benched right around 1300rms
Fosgates are amazing Amps Nigz!!! If you didn't know Fosgate was like the JL of today back in the day. But ne ways! Ur powerin' Pioneer Subs ur not going to need that 2500.1 I would recomend that RF if you had some higher end subs but the 1200.1 is an amazing amp all around and is one of my personal favorites!!!!!
Why higher end subs? the 3004spl's work well sealed and ported... they can handle lots of power and they sound very good while doing it.
Keep those subs man they're great
And that 100w is going to make ALL the difference.............or you won't hear a dammn bit of difference between them, the latter being the right answer.
I'd go for the RF, personally.
well from experience, i have two 3004 12"ers in a slot port box (built by myself) running off the kicker kx 1200 in a toyota corolla and hit 139.1 db last weekend at a iasca competion at mobilink audio in marianna, fl. the subs can handle much more power tho, by a long shot..
krazzyboy44
krazzyboy44
baton rouge
sooflashy
slater
    Oct 4, 2025
    Oct 4, 2025
