I have no use for this amp at the moment so I want to clear up some space. This amp is stable at 1 ohm and it is in perfect working condition. cosmetically its 8/10, mechanically its 10/10.
the birth sheets on these amps say an average of 1400-1500 watts at 1 ohm on 14.4 volts.
Specs:
# 1200 watts RMS x 1 at 1 ohm
# 600 watts RMS x 1 at 2 ohms
# 300 watts RMS x 1 at 4 ohms
# 1-ohm stable
# speaker- and preamp-level inputs
# preamp outputs
# cooling fan
# variable low-pass crossover (50-200 Hz, 12 dB per octave)
# variable bass boost (0-18 dB) centered at 40 Hz with wired remote
# subsonic filter (12 dB @ 25 Hz)
# three-way protection circuitry
# Amp Strapping Circuit — allows you to connect a second KX1200.1 amplifier for double the power output
# requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
# Fuse Rating 150 x 1 (external)
# THD at Rated RMS Power 0.015%
# Signal to Noise Ratio 95 dB
# Dimensions (with end shrouds): 22-1/2"L x 2-1/2"H x 10"W
$200, trades are welcome.
ill post up pictures when i get my camera back from my dad.
Specs:
# 1-ohm stable
# preamp outputs
# cooling fan
