kicker kx 1200.1
Some amps power lights are powered by the 12 volt turn on. so the amps power light can come on with no power to it. Also if you don't have any fuses it is hooked up wrong.
All that said -I have an amp that did that, I had a bad capacitor in the muting circuit.
No the 1200.1 has no external fusing.
ok to everybody i am not trying to be a azz im just saying that i have already done all the obvious things like fuses and making sure everything has power i have hooked one amp up that works fine then unhooked it and hooked this kx 1200.1 and this is what it dose comes on but just dosent put out sound and i have had it open and all apart and i cant find anything wrong with it
try taking pictures of the guts (inside of the amp) and post them up on here..
bowman26
bowman26
hodgenville, ky
ChevyRidinLow
