Kicker Impulse IX405D & IX254 (Old School Goodies)
  • 2
asianinvasion21
ai217
Kicker Impulse IX405D (5 channel)
Kicker Impulse IX254 (4 Channel)
These are both sound quality amps that are becoming harder and harder to find. This is a great opportunity to go active if you decide to purchase both amps. The 4 channel can be bridged for a more sufficient output on your mids if desired.
Kicker ix254 9/10 cosm 10/10 mech
Kicker ix405d 9/10 cosm 10/10 mech
Specs for ix254
2-, 3-, or 4-channel output
Tri-Way capable
frequency response 20-20,000 Hz
25 watts RMS x 4 at 4 ohms
65 watts RMS x 2 in bridged mode
35 watts RMS x 4 at 2 ohms
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
speaker-level inputs
preamp outputs
MOSFET power supply
two 0-18 dB bass boost circuits centered at 40 Hz
two 0-12 dB treble boost circuits centered at 18,000 Hz
two 18 dB/octave high-pass/low-pass crossovers switchable at 70 or 110 Hz
10-1/4"W x 2-1/2"H x 9-1/2"D
Dynamic Power Rating (measured at 14.4V):
Bridged Into A 4-Ohm Load: 85 watts x 2
Per Channel Into A 2-Ohm Load: 42 watts x 4
Per Channel Into A 4-Ohm Load: 30 watts x 4
Continuous Power Rating (measured at 12.5V):
Bridged Into A 4-Ohm Load: 65 watts x 2
Per Channel Into A 2-Ohm Load: 35 watts x 4
Per Channel Into A 4-Ohm Load: 25 watts x 4
Ix405D specs
3-, 4-, 5-channel output
40 watts x 4 + 200 watts x 1 at 4 ohms
55 watts x 4 + 290 watts x 1 at 2 ohms
115 watts x 2 + 200 watts x 1 in bridged mode
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supply
0-18 dB bass boost circuit (centered at 40 Hz) on subwoofer channel
two 0-12 dB treble boost circuits (centered at 18,000 Hz) on front and rear channels
two 18 dB/octave high-pass crossovers (switchable at 70 or 110 Hz) on front and rear channels
low-pass 18 dB/octave crossover (switchable at 70 or 110 Hz) on sub channel
20-3/16"W x 2-1/2"H x 9-1/2"D
dash-mountable gain controller
Four Channel Section:
Bridged Into A 4-Ohm Load: 150 watts x 2
Per Channel Into A 2-Ohm Load: 75 watts x 4
Per Channel Into A 4-Ohm Load: 55 watts x 4
Bridged Into A 4-Ohm Load: 115 watts x 2
Per Channel Into A 2-Ohm Load: 55 watts x 4
Per Channel Into A 4-Ohm Load: 40 watts x 4
Subwoofer Section:
Into A 4-Ohm Load: 275 watts x 1
Into A 2-Ohm Load: 390 watts x 1
Into A 4-Ohm Load: 200 watts x 1
Into A 2-Ohm Load: 290 watts x 1
I believe both amps are underrated and the class d section on the five channel is definitely underrated.
Kicker IX 254 $75
Kicker IX 405d $200
($250 for both if purchased together)
You Pay shipping the ix254 should fit in a flat rate box and the IX405D should cost a little more on shipping.
if a guy wanted to get both of these and go active, i have an extra sink-link. i bought 2 of them, and only need1. yes, they are real underrated. that big amp in my avatar is an ix2302. 960rms@12.5, iirc
378
906
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
asianinvasion21
ai217
asianinvasion21
Huntington beach, ca
asianinvasion21
    Apr 27, 2024
audiobaun
    Apr 27, 2024
