Kicker Impulse Amp not working
  • 2
Trancer
Allen, Texas
I have a Kicker Impulse IX402. 130 watts if I remember right. I hooked it up to 2 different systems and the Red LED on top comes on and the green power LED comes on. The amp doesnt power the sub but the sub does get powered by the CD deck. I was wondering if anyone knew whats up with my amp. Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by Trancer I have a Kicker Impulse IX402. 130 watts if I remember right. I hooked it up to 2 different systems and the Red LED on top comes on and the green power LED comes on. The amp doesnt power the sub but the sub does get powered by the CD deck. I was wondering if anyone knew whats up with my amp. Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
remove the load[speaker wires] from the amp and restart it.. did it go into protect again? check power -ground- remote and fuses on the amp. Are they ok? if so the amp is damged
616
Trancer
Trancer
Allen, Texas
chris229
    May 18, 2024
    May 18, 2024
