I have been looking at the kicker kq30. Why would it only have one input and output? How would I use that on my system. I beleive I would need 2 or 3 inputs and outputs. I have a 300.4 and a 1200.1for my system. Would this do me any good to get this
as for EQ's go, in dash i would use nothing but zapco, and i have used the all sorts of them. the zapco entry level (SP4) was way better than the top of the line arc that i was using.
as far as the inputs/outputs go, it is probably an EQ only and has no fader function. the way a lot of them work is if they have a fader and sub volume, they have one input, just pick one from the deck, fron or rear is fine, and the EQ will convert that signal into front rear and sub and have all the outputs on it. just run one rca to the EQ, and run all of them (front, rear, sub) from the EQ to the amps.
