kicker dvc sub wiring to a 2 channel amp help!!!!
bridged its at 400rms at 4ohms. if i do it bridged id have to wire in series giving 8ohms to the amp so therefore ill only be getting half of power when bridged //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
thanks for responding tho, i still want to know if i can wire the sub to a 2 channel amp but using only 1 of the channels... is it safe?
Wrong section brutha. But yes, you can wire the sub @ 2 ohm to one channel. Depending on what amp it is you might even be able to run it at 2 ohm bridged though I doubt it...
840
jr166
jr166
tulare CA
DoesDad
