Kicker 8L7 vs ed 10kv.2 ....or???
Johnnyi
Which would have more output/sound quality?
I'm looking for a pair of subs max 5.25 depth to run with 600-1000watts. I believe the Kickers have a higher RMS rating. Or another recommended sub? need sealed would perfer SQL type of application. Would like to ensure they are good subs for sealed type application. space for only .5 cu. ft box for each sub. Would like to stay around $200 or less per sub...
Tks!
what kind of sound do you want?
If you want the most output, than the l7's are probably gonna be better
if you want better sound quality and (depending on box) a more linear response, the 11kv.2's are probably the better option.
the 11k's will handle 500wrms
so will the kickers, so that isnt a real concern
edit, saw you wanted sql, depending on what you mean by that (some people look @ it differently) than the 11k's are the best bet
Johnnyi
Johnnyi
Houston, Texas
Johnnyi
