Sold Kicker 650.4 Reman. new in box
vetkilr
Just got it. Gonna go another route.Still in the plastic guys.Just want What I paid.
Askin 250.00 shipped actually paid 275.00 shipped but oh well.
Specs:
Design features
Class A/B amplifier design provides crystal clear sound quality.
Intergraded crossovers allow you to control frequency range of both full range speakers and subwoofers.
Preamp inputs allow you to utilize aftermarket head units, while speaker level inputs allow OEM integration with out the need for expensive converters.
Adjustable 18db bass boost will let your system bang down the block!
Controls are mounted on the top of the amp so it is easy to tweak the gain, bass boost or crossover frequency.
All connections are gold plated.
Includes Remote Bass Control so you can dial in all the bump you want while you are driving!
Implementation
Tri-way capable
Class A/B for crystal clear sound quality
Variable 50-200 Hz active low-pass crossover, 12 dB per octave
0-18 dB bass boost at 40 Hz
Speaker and preamp level inputs
Preamp outputs to run second amp
Soft start technology – to system pop when to turn the stereo on
3-way protection circuit
22.5" X 2.5" X 9.5" with end covers
19.2" X 2.5" X 9.5" without end covers
Specifications
120 watts RMS x 4 (4 ohm stereo)
170 watts RMS x 4 (2 ohm stereo)
325 watts RMS x 2 (4 ohm stereo bridged)
(500+ X 2 watts in bursts)
Frequency response 20-20,000Hz
High level 340mv - 10v input sensitivity
Low level 170mv - 5V input sensitivity
>95db or better signal to noise ratio
vetkilr
vetkilr
brandon,fl
vetkilr
